Children of an Auto Layout not responding to the auto vertical gap? / Also, constraints disabled possible bug?
  • September 12, 2024
  • 5 replies
  • 138 views
Celeste_F_Tysak
Hi! I’m experiencing some issues related to Auto Layout, the main one and most important, is what I describe in the title (Children of an Auto Layout not responding to the auto vertical gap). I already looked around community, Figma’s site and the web in general, tried different settings, but still can’t solve the situation.
The thing is:
I have 2 text containers within an Auto Layout. The container in the top has a horizontal and vertical resizing set on Fill, and a max width.
The one on the top, has only the horizontal resizing set on Fill, and the vertical resizing is set on Hug, but the reason I leave It like that is because otherwise, the text container resizes weirdly and both containers end up overlapping.
Bottom container in auto layout set Fill / Fill
Bottom container in auto layout set Fill / Hug
Constraints in the Auto Layout were set to Left and right / Center, and the auto layout vertical gap between items was set first to 3 and then to Auto.
Now, here’s the funny thing:
At the beginning of this post (!) the main issue was that, when checking responsiveness, both of the text containers inside the Auto Layout would respond ok-ish, but they wouldn’t follow the vertical gap no matter it was set on a number or Auto. The text container would just respond to Frame resizing, but always overlapping each other.
NOW. This doesn’t end here 🥲
I am not sure what really happened, because I actually stopped trying things on the file when I decided to create this Topic 🤣 but for some reason now the Constraints changed to Left / Center, and Left and right option (as well as Scale option) is disabled. Edit: I read about similar cases so I assume this might be a bug
Edit: The Constraints error fixed by itself, so I’m back to the main issue. I’m pasting here the file, added two component buttons, auto laid out them and then repeated the same into one Auto Layout.
Figma – 8 Sep 24
Any idea what can be happening here? I’m stuck here for the last 4 days and can’t move on since it’s quite a basic function I seem not to be able to understand. S.O.S.!
Thanks in advance for your help!
Best answer by Raphael_M
Since I’m not entirely sure what you mean, I’ll just send you a vid how to fix it.
What I’ve found in your file:
  1. Entire container is set to fix (entire thing’s height wont change)
  2. Title’s height is in fixed (even if you change text there, the height will retain)
  3. Entire container vertical constraint is in center (your added contents go both up and down instead of just going below).
Raphael_M
  • 394 replies
set this to hug
Celeste_F_Tysak
Already tried it before, just tried it again. Doesn’t work.
Raphael_M
  • 394 replies
Celeste_F_Tysak
Thanks for your answer!! I had to actually watch de video in 0.25 since our interfaces are different haha, but solved it!!
I saw you also added an Auto Layout to the bottom text, that made it work also I think.
Raphael_M
  • 394 replies
  • September 13, 2024
Ahh, sorry. The auto layout or frame is meant for the container stroke only (it’s just im used to shift+a than ctrl+alt+g)
