Change auto layout behavior at smaller size?
  • November 21, 2022
  • 344 views
WolosK
I made an accordion with auto layout so that the text fills the area as the accordion resizes, but it turns out I need the text to only be a certain maximum width. When I make the width fixed it will stay that width when the accordion is bigger, which is what I want, but the issue is when it gets narrower I still want the text to go back to filling that container. Is there any way to make this work? Or do I have to just have two different accordions for the different sizes? Here’s an example file, with one with the fill container and one with fixed width.
Figma – 10 Nov 22
Sam_Rousseau
What are you building this for? A prototype where a user needs / will change the screen size, or for engineering handoff?
If it’s for engineering handoff, I would just create two different frames - one mobile size and one desktop size with the different accordion designs (fixed and full width).
If it’s for UR - you could try this plugin:
I haven’t used it myself, but it seems like it could work for what you are trying to do
