Can't merge my own approved branch
Amanda_Espinosa
I created a branch as usual, asked for review, got approved, and now instead of the “merge” button it says that I must have editor permission to merge. Which is odd, because I created the branch and everything, I obviously have editor’s permission (I even went to check if I did). I had to ask a collegue to merge it for me.
Best answer by raquino
Hi,
This should now be fixed. We identified the root cause and pushed a fix. You may need to refresh your tab in order to get the fix. Please let us know if you are still experiencing this issue after refreshing.
  • R.J.
Alberto_Calvo
Same issue here. I’m the document owner and can’t merge it without review, and and neither an editor can, even passing review.
Sujan_Khadgi
Experiencing the same on my team on the desktop app. One of my team mates can merge and 2 of us can’t. We’re all on v 101.6 of the desktop app. However, I can merge the same branch when using the web app. Wondering if there’s a bug on the desktop app because I also started getting permission errors yesterday.
Alberto_Calvo
Just noticed that it happened because I got my Edit permissions removed in the file magically. This happened to us in another file to another person of our team yesterday. It might be the root cause of the problem.
raquino
  • Figmate
  • 43 replies
  • September 21, 2021
Thanks for the reports, we’ll look into this ASAP. Can you DM me links to the branches where you’re having this issue?
raquino
  • Figmate
  • 43 replies
  • September 22, 2021
Hi,
  • R.J.
Dylan_Mahler
@raquino I’m running into this same issue. I’ve attempted all the suggestions above, but still not able to merge my own branch even though I’m the owner of the file.
Tom_Mudgett
I used to be able to merge my own branches but now I get a message saying “Only editors can merge this branch.” I checked the main file and I do have edit access.
I quit and restarted Figma but it still doesn’t work.
raquino
  • Figmate
  • 43 replies
  • October 20, 2021
Hi Tom,
I’ll DM you for more details.
R.J.
AnnaKayKay
I am experiencing this issue right now.
Dmitry_Komarov
Same issue right now( Owners/editors cannot merge their own branches. Only admin can afford it.
Denis_Babchuk
The same issue. Refreshing tab doesn’t help.
Sukhareva_Ekaterina
And I faced such a problem
Julia_Mnizhek
  • 18 replies
  • October 25, 2021
Hi! Have the same issue right now.
BTW Thanks so much for the branching functionality ❤️
Julia_Mnizhek
  • 18 replies
  • October 26, 2021
Hi! Are there any updates on this issue? Cause I have the same problem.
Thanks in advance 😊
Matthew_Mercer
I have a branch in which I’ve made numerous updates. I am now trying to merge the branch back into the main document. It tells me “Conflicts with [file] must be resolved to merge this branch” – but there are no conflicts listed. There are a lot of elements with tags of “Added”, “Edited,” “Removed” – but none of these have any visible or flagged conflicts. Is this purely a bug? And is there a way to bypass this? I could send it to an approver for review but that was my only option.
raquino
  • Figmate
  • 43 replies
  • October 27, 2021
Hi Matthew,
R.J.
k112
  • October 28, 2021
Experiencing the same issue. Cant seem to merge my own branch have edit permissions on the file and the org.
Ksenia3
  • November 2, 2021
Hello, seems I’m experiencing the same issue, I can’t merge, After clicking “merge without approval” (file is mine so no approval needed) the file is not responding for some time and nothing merged after it’s back
wllung
  • 14 replies
  • April 13, 2023
hello, same issue. I created this file and don’t seem to have permissions to merge.
Edited: It’s a year later (2024) and I can still count on this issue to dependably happen. Main file lists me as owner and I’m being denied when trying to merge a branch.
The issue just happened to me today.
I am the product lead at my company.
I am the owner of the file.
I created the branch.
And i cannot merge without asking a fellow designer to approve my changes.
I also couldn’t address a conflict with the main file (no buttons appeared allowing me to select the main or the branch).
Desktop app on a mac. v124.2.9
Julia_Mnizhek
I have the same issue right now. I own the library file, I created a branch and I cannot merge my own changes to the file I’m owning. It’s sad.
