Can't create "Open overlay"
  • November 27, 2022
  • 4 replies
  • 560 views
Pia_West
Hi, what might be the problem, when I can’t create an “Open overlay” -connection from objects to frames in my prototype? For example “On click, Navigate to” works perfectly, but when I try to change it to “Open overlay” (or if I try to create one from scratch), the Destination field shows “None”.
James_Aduke
Hello @Pia_West,
Were you able to get a resolution to this issue? I am also having the same problem with a design.
Onkel_Tem
  • 18 replies
  • November 5, 2024
Same problem here. I don’t get how it is supposed to work.
So the Overlay drop-down list is empty.
How to get it populated?
The documentation and all tutorials out there are simply out of sync.
Nellya
  • 656 replies
  • November 5, 2024
Choose name of Overlay frame instead of None
Onkel_Tem
  • 18 replies
  • November 25, 2024
Sorry for the late response. The Overlay drop-down is empty.
And the reason for it is that my dialogs were located inside a frame. After I moved them to the top, it started functioning.
