Can I change the format of pixels in Figma?
  • February 15, 2021
  • 13199 views
Lucas_Guarneri
I’m trying to design a UI for a device that has rectangle pixels instead of regular square pixels (I know, weird uh?)
On this device, each LED dot is 0.48mm x 0.61mm. 📺
What’s the best solution?
  • Can I change the format of pixels in Figma as one could do in Photoshop?
  • Is there some solution with grid settings?
  • 4710 replies
  • February 15, 2021
That’s an interesting question! There is no way to change pixel aspect ratio (I believe that’s what it’s called) in Figma. The only solution I can see here is to use an oversized grid with 48px columns and 61px rows (or vice versa). Then you have to make all of your objects about 50 times larger to fit this grid nicely. And then do some multiplications in the W and H fields to make sizes correct (e.g. this “button” is 100w and 24h — I multiplied 100 by 48 and 24 by 61).
