Broken gradient (Tokens)
  • August 19, 2024
  • 4 replies
  • 81 views
MG17
  • 18 replies
I have an issue with a gradient which is connected to tokens on the one hand, but on the other hand, it’s not visible in Dev Mode. It should be a white (A) to transparent (B) gradient.
Gradient in the file (tokenised):
  • A: “White Token” to
  • B: “Transparent Token”
But in Dev Mode:
  • A: #fff to
  • B: #fff
Cheers!
PS: I can’t attach screenshots.
MG17
  • 18 replies
  • August 20, 2024
Again. It seems that Figma is not able to connect tokens within a gradient. I can connect them, but the output in dev mode will be the HEX codes.
So instead of having two variables as output, I get two hex codes.
MG17
  • 18 replies
  • August 22, 2024
Whoop, whoop! Anyone?
Gradient with two connected variables:
… turning to hex codes in Dev Mode:
Bildschirmfoto 2024-08-22 um 16.37.17
Output should be two variables instead of hex codes.
Laszlo_Burgermeiszter
Any progress whit this issue? I have the same problem.
For me its a bit frustrating that Figma give us a solution to connect variables for gradient start and end point, but it can’t work on dev mode. 😦
It is really important when we work on a design and hand it over to the developers.
Meanwhile I found another open ticket about this issue, where Figma support says that there will be an update what will solve this issue.
