Boolean property message "not used within component"
  • September 28, 2022
  • 11 replies
  • 25401 views
matko13
Hi there, I have a problem with creating and applying a boolean property.
I have a button that is created with nested components. I create a boolean property on the top level of a component to show an icon-only button variant. Still, when I want to apply it to the variants, it’s not visible there so I get an error that says the property is not used within a component. Does anybody have a similar problem? Screenshots attached.
  • 4873 replies
matko13
I found a different solution - in my case, instead of boolean property, It can be done by applying a true/false variant.
Matt_W
  • 18 replies
  • December 20, 2022
I have the same question/problem. The issue is that there is no intuitive way of applying the boolean property to a variant.
If there’s a help article for how to use this please can you add the link to it?
  • 4873 replies
  • December 20, 2022
You have solved my problem with this practical short video ! Thanks 💛
Pavel_Pavlyuchik
Just select component instance inside your component and press at this Zalupka
Screenshot_4
Just create variant with values TRUE and FALSE, that fix problem!
Hey I had the same problem while makink variants and component properties.
First I used this “Boolean Property” But It didn"t work I dont know why.
then I used “Variant property” With true/false an it did work
can some one please tell me why boolean property was not working?
it just hide the layer/variant
Tony_Eneh
thank you. This short video clarified it for me
Andrew_Rodin
Who developed this feature isn’t designer, the Figma was the best instrument, but just only was… All mates say, that it’s become bullshit
Ramanathan_Shrikant
Basics to create Boolean - On/Off in a component
Create component  >  Go and select LAYER that you want On/Off  >  (In right side panel) Within “APPEARANCE” section click the Hexagonal Icon  >  Use the “+” sign in the modal to create NEW PROPERTY
