Artifacts in path
  • November 1, 2022
  • 7 replies
  • 394 views
Giorgio2
Hello,
I am experiencing what seems to be a bug. When I import a path in Figma, it shows some strange artifacts.
ImgBB
This artifact also shows when exporting to raster (PNG).
It seems to be something having to do with pixel hinting. But I cannot get rid of it.
Anyone knows what might be causing it?
Thanks
Aguiar_Leonardo_extern
Hi, thank you for sharing. Having the same issue. My file that has this issue is using clip paths. Other vector files without clip paths don’t seem to have this issue. Did you find a solution?
UPDATE: I edited the paths of the vectors and the problem only happens to vectors that have a subtract boolean operation happening to them.
Celine_
  • 3751 replies
  • November 18, 2024
Hi there! Thanks for flagging this and sorry to hear this is happening.
I can’t replicate the issue on my end. Is it happening on browser, desktop app or both?
Usually, GPUs have known bugs and may cause rendering glitches / artifacts when using Figma. To cover some grounds, I would recommend you to check the Figma browser requirements in this article:
Figma Learn - Help Center
Please also reach out directly to the support team with a URL of the file so they can investigate further and try to reproduce it: here
Please use your Figma account email, include a link to the file, and add support-share@figma.com as an Editor, so they can take a closer look. Thank you!
Happens on desktop app and browsers. Shared a file and sent it to the support-share email you provided.
Celine_
  • 3751 replies
  • November 21, 2024
Thank you! I see in the backend that we’ve submitted a bug report for our engineering team to investigate. We’ll provide updates as soon as we have more information. In the meantime, please continue to track this issue through your support ticket. Thank you for your patience!
Hi, is there any update on this issue? It continues to happen with other vector assets as well. It is frequently happening on curved vectors.
Celine_
  • 3751 replies
  • May 6, 2025
Hey  ​@Aguiar_Leonardo_extern!  I’ve checked in the backend, our engineering team is working on a fix, and while I can’t share an exact timeline, we’re hoping to have it resolved soon.
I can see your support ticket with the technical quality team, and rest assured, we’ll follow up with you as soon as there are any updates.
We really appreciate your patience and understanding while we work on a solution! 🙏🏼
The Twin Peaks Menu
This is likely due to subpixel rendering or how Figma handles anti-aliasing on vector paths. Try aligning your paths to full pixel values or applying a small blur (0.1px) to smooth edges. Also, double-check if "Pixel Preview" is on, which can reveal how vectors align to the pixel grid.
