JaFu
May 15, 2022
Allow us to pin plugins
  • May 15, 2022
  • 4 replies
  • 2687 views
Pinning plugins to right-click menu
A new section with the plugins you pin (it’s an option when you right-click a plugin from the regular menu). I don’t think I could explain this more.
Pinning plugins to toolbar
I think it could look something like this:
When you would click the icon, the plugin would pop up like in illustrator, only it would have the UI of the plugin.
It could only show up to 3 icons and the rest would be in a “more” menu. You could pin 3 plugins. If you do this, two more slots appear, showing the two most recent plugins you used that aren’t pinned but have been added to the toolbar. when an app is pinned like this, you can move it around like normal. However, when you launch it from the top it gets snapped to the top under the icon and the close button would minimise it. If I should make a hole Figma UI redesign, just ask.
August 13, 2022
Daria_Michalska
Would be great to have an ability to pin plugins for easy and quick access. Just like it’s done on FigmaEX
Nilam_Hembram
December 13, 2024
Would be great to i have an ability to pin plugins for easy and quick access. Just like it’s done on FigmaEX
Sharen
Hi Figma team,
I'd like to suggest a feature for the Plugins & Widgets panel.
The Problem:
When I use different plugins, my frequently used plugins scroll down and disappear from the list. I have to search for them again every time, even though I use them constantly.
My Suggestion:
Add a star or pin icon next to each plugin or in the three dots. When I click it, that plugin stays pinned at the top of the list. This way, my favorite plugins are always easy to find, no matter what other plugins I use.
Why this helps:
  • My most-used plugins always stay at the top
  • I don't have to search for them every time
  • Faster and easier workflow
Please look at this feature request and consider it.
Thank you for your time and attention.
