After the latest update "multi-edit" push changes to the main component changing only 1 variant
mo_hamwi
After the update of multi-edit , the indicator in component that locate the element in all the variant is disappeared , Accordingly the push changes to the main component is not updating the changes of elements properties in all variants ?
I think this should be fixed , and I suggest the “multi-edit/select” should have it’s own tool , not integrated with the main “select” tool.
  • March 11, 2024
Hey there,
Thanks for reaching out. I’m checking this with our internal team. I will get back to you when I have anything I can share with you.
Gregor_Kruger
Same issue here. Is there really no update since march?
