We need max and min character on text property
rahend
hi Figma, i need your magic.
I require both a maximum and minimum character limit for the text property. This will allow me to establish clear guidelines for UX writers, ensuring that their content fits within the designated character limits and maintains a tidy design and layout.
  • 3915 replies
  • October 26, 2023
Hi rahend, thanks for sharing your feedback.
I’m adding some additional tags to your suggestion to surface it a bit better for others who are looking for something similar!
Day_Brandy_D
I need this function as well. Right now editors have to count them and delete the excess, increasing time to production from prototypes.
Travis_Rogers
This seems like an easy win for Figma as it’s trying to better comply with development. I need this feature as well!
Benjamin_Margoux1
Need this too. Currently I use max-width/height on the components of my DS but if does not create the same results while resizing text-containers.
Stijn_Swinnen
I need this too. Currently we are mentioning the maximum amount of characters in the mockup or renaming the layers. While this works for our copywriters, it would make sense if there’s an actual, dedicated setting for this. It would help us both in wireframing new pages and briefing our copywriters.
Systems_Innovations
This would be very helpful for me too.
Also, I’m curious about having the same width and height yet the character count vary. Is it because of the font style?
For example, if I type ‘check-in essentials’ to max it out on a text property with 456 width, I can only fit up to 20 characters on text property. However, if I type ‘almost there’, I can go up to 23. Anyone knows why that is the case?
Need this feature as well! It will definitely streamline collaboration between the copywriters, designers, and developers!
Henry_Babbage
This would help me a lot when handing off designs to editors, for them to have a built in measure of character limits for a text container.
Bruno Araújo
Textbox height does not take into consideration font character width/size/etc. Different fonts would fit a different amount of characters within the same textbox height. Not to mention it would help us while designing – set a component's label to 20 characters max and you wouldn't accidentally go over the limit without realising (or having to double-check every time you have new copy for a button). Not to mention it would mirror development for the hand-off.
Dennis_N
  • 194 replies
  • May 27, 2025
We urgently need this aswell to protect the design. Someone needs to limit the damn marketeers 😅
JettyLou
  • 11 replies
  • July 11, 2025
Its 2025, this should not require a plugin
