Jens_Nielsen
Mar 19, 2021 8:41 PM UTC
Specify center of rotation
Is it possible to specify an objects center of rotation.
I cant for the life of me find it anywhere.
You could do this relatively easy in sketch.
Power Member
Mar 19, 2021 11:44 PM UTC
No, it’s not possible. You can wrap objects in a frame with the center in the necessary coordinates and rotate the frame.
zhangxiaochun
Jun 3, 2021 8:11 AM UTC
This is a temporary solution to solve the problem, but not a way intuitive.
Hope Figma could launch a feature to set the origin of rotation. It will helps a lot when drawing icons.
Darren_Kurre
Feb 15, 2022 4:34 PM UTC
There is a plugin to Change the Origin of Rotation by Andreslav Kozlov, but it can be a bit tricky to get right if you come back to try and rerotate an object in the middle of an animation later. Point of rotation is a very simple feature that should be native to Figma. It’s a huge factor for micro-interactions and animations that has been around since the early days of Flash and is in virtually all vector based and non-vector-based prototyping and animation software. PLEASE ADD THIS ASAP!!!
Theodora_Foien
Apr 18, 2023 12:49 PM UTC
Replying to keep this alive. I also support this. This should be a core feature of Figma. Please add!
Apr 18, 2023 5:06 PM UTC
Thanks for chiming in, @Theodora_Foien!
We’ve updated this topic to a feature request, so we can gauge interest from the community & pass it along to our developers for future consideration. Don’t forget to Vote! 👆
Hans_Oksendahl
Jul 10, 2023 7:21 PM UTC
@dvaliao Any chance you could link to the feature request? I would like this feature as well it would greatly simplify being able to export SVG layers for the purpose of animation.
andrea-hg
Sep 11, 2023 7:28 PM UTC
Yes please, @dvaliao! 🙏🏼 Better rotate and mirror tools are super needed for vector work. We should be able to specify origin for both actions. Illustrator has a pretty good solution for this.
Kenneth_Sebesta
Oct 3, 2023 3:49 PM UTC
I watch a Figma presentation at Boston University yesterday, and was amazed at how effortless it appeared. Today I tried to make my first mockup, a gauge cluster, and came crashing into this lack of feature. I tried several plugins-- the Rotate Origin plugin was most promising but is badly broken and yields highly inconsistent result–, before finding this thread. So there seems to be no trivial, joyful, way to make something as simple as a line which rotates around an arbitrary origin.
I’m sure there are creative workarounds, but as this was my first usage of Figma, I’m not particularly keen on investing in those from the beginning. Being able to define a center of a transformation is-- or at least should be-- extremely low-hanging fruit.
Oct 8, 2023 9:21 PM UTC
Yes please, this really should be a feature
Simon_Wehrli
Nov 9, 2023 10:04 AM UTC
Did you find the link by any chance?
