Adam
Jan 28, 2021 7:52 PM UTC
Resizing elements with constraints should actually respect the constraints
When you resize an element with right constraints inside a parent layer, the element expands towards the right and off the page (layer). I can’t think of a scenario where I would want this behavior. When I set a constraint, I don’t want to readjust the spacing from where it was originally while editing.
Can anyone think of an example where this would not be desired behavior?
Power Member
Jan 28, 2021 11:31 PM UTC
Yep, that would be nice. Auto layout layers already do that when you resize something inside of them. Why not regular layers?
Phil_Larsen
Jul 29, 2021 10:30 PM UTC
Yes! I have been spending a lot of time moving an element that is in a normal frame despite it being constrained to the center, or right. Seems to always resize as if it were left aligned.
Ashley
Aug 15, 2023 7:35 PM UTC
Use-case: I’m building an icon with a badge. The badge is aligned right/bottom over the icon. As I adjust the size of the badge using the width and height values it should stay right/bottom aligned.
HypoSim
Feb 1, 2024 3:23 PM UTC
3 years later, and still not fixed… 🤦
Neal2
Jun 7, 2024 2:19 AM UTC
No matter how much I changed the anchors it didn’t work, and I kept thinking I was doing it wrong, I suggest constraints renamed confused.
