Jul 12, 2023 7:24 PM UTC
Quality of Life Improvements for Variables
First and foremost, I’m really enjoying using and experimenting with what I can do with Variables. I have barely scratched the surface but feel like these are obvious improvements that should be included in the backlog somewhere:
  • Ability to duplicate Variables
  • Ability to duplicate a Collection
  • Ability to move Variables to another Collection
  • Ability to move a Group to another Collection
  • Ability to move multiple Variables (between Groups and Collections)
  • Add a description for Collections and Groups (I don’t want to repeat the same thing with slight variations for each Variable)
  • Ability to search for a Variable or Group within the Variables window
  • Ability to move the Mode columns within the Variables window
  • [EDIT] When creating Color Variables, I wished that it remembered the last panel I used to create the previous Variable. This would be useful when I’m creating multiple semantic variables via aliasing
  • [EDIT] Ability to scope multiple Variables that are of the same type
Thank you so much for making our lives easier (and keeping us busy) with Variables! Keep up the good work!
Daniele_Q
Oct 8, 2023 11:22 PM UTC
100% Agree with all of them.
Oct 11, 2023 7:15 PM UTC
Karl_Mochel1
Oct 18, 2023 4:46 PM UTC
It is confusing to set up variables and variants. I can’t do them in a way I feel is intuitive.
  • Not being able to assign Modes to parent components.
  • Properties not settable on the layer that I expect them to be.
  • Properties not available at parent layers like I expect them to be.
  • Having to use booleans in odd ways to get expected results.
  • Not being able to set up properties with conditions that work in Design.
Sandi_Bennett
Oct 19, 2023 10:12 AM UTC
Using variables has significantly improved workflow efficiency and collaboration with developers. However, I’ve encountered some issues while using them, and I’d like to provide some feedback:
  1. When deleting variables from a library that you’re importing, on the component level, it doesn’t always recognize the deleted variables and displays them as ‘used.’ It appears to be a common issue, as reported in various forums.
  2. When applying a variable to a child ‘control’ element and then applying another to the parent element, there should be some feedback or alert suggesting that a variable is already applied to the parent. Without such feedback, manual investigation is required to ensure that there are no variables applied at the child level that may be preventing the parent variable from updating.
Terence_Curtis
Nov 1, 2023 12:35 AM UTC
Adding an idea: It would be better if the variables modal did not auto resize when selecting a variable
Terence_Curtis
Nov 1, 2023 12:36 AM UTC
Adding an idea: Would like to be able to see a list of variable that are part of an external library
Michal_the_UX_guy
Nov 7, 2023 6:45 PM UTC
Hello,
I would like to provide feedback for Beta Figma Variables.
Message: Variables are a great tool for building design systems, and I’m rooting for them. However, to maintain the quality of implementation and design consistency, it’s necessary for variables to function as they should. I have a few observations from my colleagues and myself during the 2-month testing on our projects.
UI window for Variables:
  • The Variables window should not be part of the Figma canvas, but should be a separate window that I can drag anywhere outside the canvas as needed. (One window for Figma, another for Variables)
  • Placing the button to create a variable at the end of the block doesn’t make sense, button is too deep. Should be also on top of the Window.
General Variables:
  • Variables should be able to calculate between variables
    • For example: If I’m setting a unit system, and I set an 8px unit system within the project, I should be able to generate a set of the entire unit system easily with a simple notation: baseUnit * 0.5, baseUnit * 1, baseUnit * 2, baseUnit * 3, and so on.
Color Variables:
  • Font colors are specified in RGB. Today, RGB is practically unused, and we would like to display colors using other formats such as HSL, HSB… to be possible make color schemes and be more readable in variables window. (For example some switch to other formats)
  • Gradients are missing. Just like with solid colors, it should be possible to define gradients. In styles, we use combinations and we would prefer not to set the color once from Variables and once from Color Styles.
Font Variables:
  • I understand that this is still in preparation. However, we would like the option to define variables independently for:
  • Font weights (300, 400, 700, 900, etc.)
  • Font sizes
  • Optionally, style (strike, small caps)
  • Font families
Certainly, this is not everything, and I would like to invite more people with their own experiences to join the conversation.
For example, from the Figma Tokens plugin (where the above-mentioned things are possible, but in terms of usage, they are too slow to change). Good luck, Figma Variables! 🤞 🫰
If needed I can make presentation for Figma Team. 🙂
Adam_M_Babkes
Nov 7, 2023 7:07 PM UTC
My feeling has been that it’s amazing to have this baked into Figma vs. using a plugin as it’s much more efficient. Looking at a plugin like Token Studio, there are a few features that I really feel the Figma Vars should incorporate.
  1. Ability to use “em” defined within the variables as “em”
  2. Ability to use Aliases and do math on them {paddingDesktop}*.5 for instance
Is there a roadmap anywhere for this feature? It’s amazing to have it, now it’s time to get behind it and really make it go.
Keve
Dec 1, 2023 1:39 PM UTC
I experienced quite controversial output when I tried to set heavily nested components.
  • level 1 → icons (size, states)
  • level 2 container (type-> icon, checkbox, counters, avatars, etc.)
  • level 3 - button base (size, including container, roundness)
  • level 4 - states and button types (primary, secondary, outlined, link, etc).
After I set it up carefully the different sizes totally messed up the colors, I needed to reset all changes and switch to size and states, to get the correct result. I think the variable overrides are the main problem because I made this with styles and works flawlessly.
Zlatko
Dec 22, 2023 8:34 AM UTC
How about storing textures in a variable value? Is that considered in the beta?
Maker of kinverse.app
