Yuwen_Li
Aug 31, 2023 7:16 PM UTC
Published Variable Adjustment - Editing Non-Local Variables
Can I edit the variables defined in a published library locally?
  • There is a library file (Say File A) with a collection of local variables defining some string and numbers shown on a component. The component is published (with all variables too)
  • I added this component to another file, say File B, but when I want to edit those strings and numbers locally in this File B, I can no longer see the these variables, nor editing them.
  • Seems like I can only edit the published component in the library File A (if I have edit access) and this will change all the instances too.
Can I instead edit it locally, meaning edit the values of these publish variables only in File B?
Ygor_Henrique
Dec 4, 2023 2:01 PM UTC
@dvaliao hey Denise, if you have a workaround to change a publish variable library locally to meet my client colors let me know, please!
Corey_O_Brien
Dec 5, 2023 4:57 PM UTC
Exactly. The variables don’t work much for us unless we get this. We build design systems that are used by multiple projects and clients. If we can’t change things like colors or sizes of border radius, it makes using variables in the system a waste of time a bit.
Ygor_Henrique
Dec 6, 2023 4:00 PM UTC
simple as that. Variables was meant to be scalable but it is not at the moment due to this limitation!
aetinx
Dec 6, 2023 7:11 PM UTC
@Corey_O_Brien @Ygor_Henrique Be sure you guys voted the post! 🙏
Adam_Kliegman
Feb 1, 2024 10:04 PM UTC
We definitely need this!
As a user of a library, I want to be able to update and/or override Library-defined variables so that I can theme different files without core access to the Library
May 31, 2024 6:19 AM UTC
@dvaliao can you give an update/feedback from the Figma team for variables if they put this into the roadmap and if so when you estimate it to arrive ?
To me this seems an essential feature as @Corey_O_Brien describes it is same for me and I wonder how we could spread more upvotes to this! Thanks
May 31, 2024 6:23 AM UTC
What I am trying so far is:
Publish my components that do use variables as a library but exclude the variables from publishing. Then in the file using the library, create the same-named variables.
Instances do carry the variable name - but the values do not stick to the local variables.
I wonder if there could be a plugin / script to run through all variables and connect them.
May 31, 2024 3:50 PM UTC
Hey @Martin_Bertele, thanks for following up!
The team is already aware and monitoring this thread, but they don’t have a timeline to provide at this time. Be sure to keep an eye out on our future releases.
Jun 3, 2024 6:39 AM UTC
A workaround: export/import variables plugin to have them locally and then edit them.
StanTravels
Jun 28, 2024 5:24 PM UTC
Unfortunately, this plugin is useless because it doesn’t create references to the imported variables for existing components. This means they continue to use the original design system’s variables, requiring you to manually adjust them to the newly imported ones, which can become an incredibly tedious task.
For companies with many clients who want to reuse their corporate design system with some adjustments in branding and UX writing across various projects, this feature could have immense value that cannot be overstated.
@dvaliao we all would be glad for even a small hint if it’s in the roadmap or not 😉
