Charles_Lai
Jun 3, 2021 4:24 PM UTC
Prototype: disable navigating screens through keyboard (left/right buttons)
When using a Figma prototype, there should be a way to disable the ability to navigate through screens via left & right keyboard buttons. Some research participants are inadvertently skipping through the prototype this way, rather than clicking hotspots.
Is anyone using a plugin or workaround to help solve this?
BaptisteE
Aug 27, 2021 1:44 PM UTC
+1
That’s a major issue we experience in our team presentations and with research participants.
Jan-Niklas
Sep 24, 2021 2:23 PM UTC
+1
Also I am not sure how to organize the pages within the prototype. It does not depend on the structure of the layer panel! Can someone help?
e_c
Oct 14, 2021 8:22 AM UTC
Figma gets the prototype screen order from the canvas. From left to right and top to bottom.
Avery
Jul 19, 2022 8:14 PM UTC
Yes! I just figured out that navigating with arrow keys is why prototypes don’t seem to appear in order. This is a problem. I need a way to disable this so that it doesn’t cause any further embarrassment.
Dana_Heimann
Aug 16, 2022 6:15 PM UTC
I have this issue with pagination as well. My screens do not show up in the order in which I have prototyped the flow. A previously closed chat here in the forum on the same topic does not solve the issue. @tank666 states:
Change the order of the frames on the canvas in your file. Note: Figma orders frames based on their co-ordinates in the canvas. First, by their x co-ordinate from left to right, then their y co-ordinate from top to bottom. If the y co-ordinate is offset in any way, then frames may appear out of order. To fix, you can set horizontal alignment for each row of frames to align-top.
My prototype is more complex than this. I have 32 frames and nearly double that in hotspots. Horizontally aligning all the screens would make extra work and (according to numerous others in the forums) not solve this problem. I’d like to add a comment from Gavin McFarland on a 2018 archived Spectrum chat on this very topic as it perfectly mirrors my problem with this issue:
I guess I don’t understand why you would order the frames by their respective hotspots. Screens that are connected by a flow don’t necessarily follow a linear hierarchy, so I don’t know how you can predict what order is best for the author.
@Charles_Lai has a good point in that navigating linearly with arrows is often confusing for participants and does not follow the flow of the prototype desired by the designer. So, Figma, is there a way to hide the left/right arrow flow through the prototype? Or some way to manually paginate based on layer order? Or another manual way to reorder the screens that is not based on hotspots or x/y-axis positioning? Would love to know any updates on this! Thanks 🙃
Avokadomos
Figma Ambassador
Figma Ambassador
Aug 18, 2022 11:00 AM UTC
You can disable key navigation by assigning unused interactions to the frame. For example:
This will prevent default behavior. It does take some manual work to set up though.
Disclosure: I’m part of Figma’s Forum Ambassador program.
Avokadomos
Figma Ambassador
Figma Ambassador
Aug 18, 2022 8:22 PM UTC
I also want to add that there’s this setting right here:
If you’re using the browser app, the URL will update so that the presentation can be shared with this setting on. I noticed that the link that you copy from the desktop app does not include the setting.
Averyy
Sep 21, 2022 9:42 PM UTC
The setting should be set on the prototype itself. When i select to “disable keyboard navigation” and share the link by the Figma app, it allows the viewer to navigate via keyboard by default. If i close that prototype view and open it again now the option “disable keyboard navigation” is back to unchecked.
Whats the point in having the option if it doesn’t do anything and doesn’t save the state?
Nick_Angiolillo
Dec 13, 2022 2:58 AM UTC
Big +1 on this. I prototype for TV apps where communicating accurate behaviors of the left/right/up/down keys is essential. Some sort of setting in the Prototype panel at the Flow level to shut down all default interactions would be great.
tank666
Dec 13, 2022 9:23 AM UTC
