Micha
Dec 15, 2023 9:54 AM UTC
Organisation of swap instances - prefered values
Better organization of content in submenus in the design area.
Sometimes I use the slot method to compensate for missing options and possibilities in Figma.
Here is an example: “Edit instance swap property”.
I have about 20 favorite objects. But they are not organized in the window. Neither thematically nor alphabetically. So I have to do this manually. An autoscroll function is missing here. This means selecting several objects, moving them up or down and using auto-scroll to move them to the desired position. The “preferred values” are also not passed on. So if I have prepared a slot with preferred values and copy it, for example, 8 times (for 8 slots), these preferred values are not included.
“Refresh” in the context menu of a warehouse (slot). Right-click to open the context menu and select “Swap instance”. All “preferred values” are not in the previously manually created order. That means all the work again, for each slot 🙈
Thanks
Gayani_S
Dec 15, 2023 2:43 PM UTC
Hey Micha, thank your for your feedback! Please don’t forget to upvote your feature request.
Alberto_Mate
Aug 15, 2025 4:29 PM UTC
I feel the same pain, but multiplied by XXX. Around 30 templates, with 5 to 15 sections each, and with an average of 10 slots each. Duplicating a slot should carry over the preferred values. Or at least we’ll need a way to copy and paste them, instead of doing the same work again and again. Performance, efficiency =  ZERO. And it causes to increase human error which is completely undesirable.
