Birgit_Stenzel
April 22, 2021
Launched: Manual resizing of sticky notes
  • April 22, 2021
  • 51 replies
  • 12016 views
1. Describe the bug/issue you’re running into?
I can’t resize sticky notes manually - this would be really nice though. I’m not sure if it’s a bug or a feature, but it feels like a missing Feature.
2. Are you able to consistently reproduce it? If so what are the steps?
Yes. Post a Sticky… try to change it.
3. Share a screenshot, recording, console log, link to the file, etc.
4. Is the issue only happening in desktop app or a specific browser , or both?
I can only test it in the browser Mircosoft edge (company policy…)
5. What OS/version and/or browser/version are you using?
Mircosoft Edge Version 90.0.818.42
Igor_Lacerdino
April 22, 2021
+1
I’m creating a click flow diagram and I wanted to add sticky notes to some steps with questions. The workaround for now is to re-size the entire flow diagram but it is more work to adjust text size later
samtcg
Hey there 👋 At this time, stickies cannot be resized. Stickies have a set width and minimum height. The height will change based on the amount of content you add to them. You can find more info in this Help Center article: Resize, scale, rotate, and flip objects
Kartik_Subramanian
April 28, 2021
Hi there,
I’ve recently started to use FigJam and I believe it’s a great tool to rapidly flowchart and communicate ideas to a team. I want to leave a sticky note in a couple of places and many a times they vary in the type of content within them. Can you please allow for a feature to re-size the sticky note?
Thanks
Igor_Alexandroff
April 29, 2021
Maybe you have it in plans at least?
Because I miss this feature so much and now have to use Miro instead…
Samson_Kirigua
April 30, 2021
This was the first thing I tried to do with sticky notes 😀
Yeah! … I need this feature.
Thanks!
Devansh_Raj
May 2, 2021
I want the sticky note to resize horizontally too for long titles.
And can we have multiple text style in one sticky note?
Because I want to use it for work and define the title and then the points in different text in the same note.
Adam7
May 3, 2021
This seems basic and throws off my workflow when transitioning from Miro (well, assessing if it’s possible, little things like this make it hard to convince unfortunately)
Nadia_Eldeib
May 6, 2021
+1 to this. Also, it seems like this functionality existed but went away? I noticed a weird behavior if I grouped a sticky note + dot sticker, then tried to resize. The dot sticker would overlap with text. Now I can no longer figure out how to resize at all.
Polca_Creations
May 18, 2021
Please make it possible to resize Sticky notes on FigJam.
Cait_O_Reilly
May 20, 2021
Would love the flexibility to resize Sticky Notes and have the text size also increase/decrease in size. Having fixed text styles doesn’t provide enough variety.
