FIX LAUNCHED: Unable to Reorder Properties on Component Set
Petr_Sevcovic
Drag and drop to shuffle properties of components doesnt work with new UI. It work fine on old one.
Glenn_Cahill
  • 5 replies
  • October 19, 2024
This seems to be very hit and miss as to when it works and doesn’t work (doesn’t most of the time).
conner_monarch
In UI3, I am unable reorder the values in a variant property of a component. I have a progress bar trying to go from 0% to 100%, but the values are stuck and not in the same order in the autolayout frame of the variant.
Marcius
  • October 21, 2024
I’m having the same issue and it’s a really annoying bug. Can you guys help us here?
Rosemarie
  • October 21, 2024
Yesterday, suddenly, I couldn’t reorder property values while I created my components.
Dragging them doesn’t work.
It is frustrating for me to work without this feature, it is very important for my system’s organisation.
I found some topics back in 2022 that this bug happened again.
  • 2545 replies
  • October 21, 2024
Hi all, thank you for flagging. Our product team has confirmed it’s unintended, and we’re working on a fix that will be rolling out shortly to resolve the issue. We’ll let you know once it’s fixed.
Thanks again for your patience!
Toku
  • 4910 replies
  • October 21, 2024
Hey All, thanks for your patience!
We launched a fix for this about an hour ago. Please refresh your tabs and let us know if you run into any further issues.
waqarnaik
  • Active Member
  • 22 replies
  • October 21, 2024
Thanks now its working absolutely fine 🙂
Glenn_Cahill
  • 5 replies
  • October 21, 2024
Amazing! Thanks to the Figma team this is working great this end!
Sean_Walsh
Values of Properties were fixed, but not reordering the Properties of a Component. When is that going to be fixed?
  • 2545 replies
  • October 29, 2024
Hi there,
Thanks for the comment! I think it seems to be working.
Please let me share the help center article for more information on reordering. Variant properties always appear above other property types in the right sidebar. They can be reordered among other variant properties but not with different property types.
I hope this clarifies things, but feel free to let me know if I missed anything important!
Toku
Sean_Walsh
Well it wasn’t working at the time that I posted. Before I posted I restarted the app and even checked on the online version. Both had the same issue. Now the handle bars are present when I hover over the property.
Thanks for assuming I didn’t know how to use the app. 👍
Stephanie_Pekala
I am still having this issue in my Figma. In the file I created the component in the variants are in one order, but whenever I bring it into another file the order does not match. Is this a known bug that is getting fixed?
Sarah42
  • November 19, 2024
I’m also still having this issue as of nov 19!
Simon_Archer
I’m also having this issue, where I’m unnable to drag suffix and prefix below, so the “Suffix Label” is underneath the “Suffix” toggle
Smith_Samuel_D
Hey Simon! This is a feature of Figma and not a bug. Variant properties are forced to be at the top of the list, while all other property types (Text, Instance Swap, and Boolean) can be re-ordered below the Variant properties. 🙂
Teddy
  • 4 replies
  • April 14, 2025
I’m having this issue now as well. I know it says a fix was pushed, but I’m struggling to move around variants to set them in a specific order now. When I go to select a variant it moves the wrong variant.
jesiUMKC
  • April 15, 2025
I am also having the same issue. I cannot re-order my values in a variant property menu. It shows the little hand grabber, and often selects/the wrong one and moves it randomly. It’s incredibly buggy and stopping my workflow on this component. I’ve refreshed the tab and restarted figma and it still is happening.
Teddy
  • 4 replies
  • April 15, 2025
I did the same with the same result. I ultimately ended up having to flip to UI 2 to get things to order properly.
