Bohdan3
Figma UI3 problems - component properties block shown above "Position" block
  • August 5, 2024
  • 114 views
When you select component, its properties show up at the top of right panel. So block with “Position” properties moves down. This is so inconvenient and confusing 🫣
Bruh
Hi there,
Thanks for the feedback! I I understood your point and will share it with our internal team.
Toku
Dennis_N
Power Member
November 7, 2024
To me it already happened a few times that I changed the x/y-axis instead of the elements size because the position changed. Now I carefully need to check if I am changing the values at the right place. This costs time and could easily be fixed by having these values again back at the top to avoid elements changing their position.
