Darrin
Apr 23, 2021 9:50 PM UTC
Export images at original size
If I add an image to figma and then resize that image I would like to export it at the original resolution. Maybe if there was even a button to resize the image to the full size.
2. Add as much context as possible (screenshots, Figma files, mockups, etc.)
**3. Ask questions to bring the community into the conversation **
(e.g. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this?, etc.
Denys_Romanko
Jul 20, 2021 7:31 AM UTC
I know a way how to export 100% scale image but it is not so easy.
Select a frame/rectangle with the background image and on the property panel set Image Fill type to “Tile” and next to it 100%. Then correct frame/rectangle size to fit only one image iteration. And export it as 1x.
Hope it will help.
tank666
Jul 20, 2021 9:28 AM UTC
The original image can be obtained in this way:
Julian_Dik
Oct 6, 2022 8:35 PM UTC
I had to login to like your solution because it helps me so much. Thank you!
andpetre
Jun 28, 2023 3:57 PM UTC
If you want to see the original size of an image you can select the image, go to Fill, change it yo crop with 100% and you will see the actual size of the image.
Yassine_BENRAHMOUNE
Jan 9, 2024 10:20 AM UTC
To export the original image, just switch to dev mode, click on the image and export it from the toolbar on the right.
Dima_Novosad
Apr 2, 2024 9:46 PM UTC
Mom, how do I turn on the TV? You need to go switch circuit breaker at the substation!
coodersio
May 15, 2024 1:46 PM UTC
Hi, can this plugin help?
Figma
NickP
Feb 28, 2026 1:46 AM UTC
This doesn’t work anymore. I run into this problem a few times a month.
Quincho
Aug 31, 2026 10:19 PM UTC
Select the element (in this case your frame); Go to the Inspect tab; In the Code section switch to the Table view; Click on the image.png link.
 Este​​​​ proceso es el que si sirve, gracias!
