Enable push/pull of elements below a resizeable component
Lena13
Hi all,
I am wondering if it is possible to enable a “push/pull elements below”-function. In my current case I have an accordeon component that changes size based on what instance is selectet / interacted with.
Below this component sloser to the bottom of my screen are texts and other elements that are currently “overwritten” by certain expanded instances of my accordeon.
In my previous job I worked with Axure and there one can simply select “push/pull widgets below” when adding interactions to a component and all elements on the screen below will be pushed/pulled by the exact difference in height of changed component.
Is it possible to add this option in Figma?
(I know I could just add all other elements to my component but this would blow up said component way to much and seems unnecessarily complex)
  • 2545 replies
  • April 22, 2024
Hi there,
Thank you for sharing your idea! We greatly value your feedback, and we would like to gauge the reaction of other members in the community. We may consider it for future enhancements!
Toku
Mike_Scarpiello
This would be very helpful.
Mike_Scarpiello
@Lena13  I figured out that is you put the whole page or content that you want into auto layout, you will get the desired result.
