Johnson_Ryan
Apr 17, 2024 5:23 PM UTC
Configure font weight and font style separately
It’s great that I can use variables within Text styles, but there’s a large problem with configuring font weight. I want to use number variables for my font weights. Unfortunately, if I want italics, I am forced to use string variables for my weights.
Figma clearly has logic to isolate font-weight and font-style from the chosen weight configuration in the UI (as seen in CSS code output), so why can’t I configure these two properties separately and Figma recombines them on the backend to identify the font face to load?
May 21, 2024 11:18 AM UTC
And when we use string variables for font weight and font style, those two properties won’t be shown as varibales in CSS code output, it’s a huge problem when it comes to mapping designs tokens …
We (Designer and Devs) really need the possibility to set font weight and font style separately! @Figma_Moderation
Franco_Andrade
Sep 15, 2025 8:36 AM UTC
​@Shan ​@Johnson_Ryan have you guys found any work around for that problem?
Johnson_Ryan
Sep 15, 2025 4:15 PM UTC
The simple solution for us was to avoid defining italic text styles. If copy needs to be italic, it can be applied ad-hoc (which aligns with how HTML/CSS would be applied on top of a base style).
Doing this, we were able to define entirely numeric weights.
