Ted
May 18, 2021 6:52 PM UTC
Bug: Some objects aren't prototype linkable
Very strange bug. I can’t add interactions to some objects, and I can’t see any reason why. Basically I have a group with a couple of shapes in it, and when I am on the Prototype tab, it doesn’t show a “+” to the right of “Interactions” and it doesn’t show the link handle in the main area.
Screen Shot 2021-05-18 at 2.48.36 PM
Above: a normal selection that I can link
Screen Shot 2021-05-18 at 2.48.28 PM
Above: an abnormal selection that I can’t link.
The only other differences between the two selections that I can find are in the Design panel:
This is the normal one
And this is the abnormal one.
Any ideas?
Mathijs_van_Miert
Oct 19, 2021 2:49 PM UTC
I have the same issue. Do you know anything yet?
Lee_Brown
Dec 6, 2021 6:50 PM UTC
Experiencing the same bug right now. Objects are embedded in two frames. Not sure if that matters.
Danny_Chambers
Jan 18, 2022 12:03 PM UTC
I’m also having this issue. Under a deadline and really need a solution -
John41
Aug 2, 2022 2:02 PM UTC
Pop the objects to the surface by de-embedding them. Add your prototype connections and then re-embed. Worked for me.
Apr 18, 2023 2:25 AM UTC
Anything for this bug yet? Huge issue for my prototype right now
Jul 12, 2023 8:22 PM UTC
I just discovered the same issue in my own prototype. I tried grouping a selection of shapes to see if that enabled me to make connections. It didn’t. I’m supposed to finish my low-fidelity prototype as an assignment and coming across this bug and finding out there isn’t a fix yet is incredibly stressful.
Nov 26, 2023 9:34 PM UTC
I had the same problem. Saw that I can only connect the shapes that are grouped. So I put every line, every shape I had into the group (site) it belonged to and then could connect them with other sites. So basically check if at the left panel, where you see all your shapes, everything is grouped based on the site. If not, then drag them under the site name they should be. Hope this helps!
Feb 7, 2024 11:49 AM UTC
Try framing the object using ‘frame selection’ option . Worked for me.
691124900
Sep 23, 2024 9:34 AM UTC
no scuh thing as sx etc
