Allow link to be clickable when using embed links from Figma to Behance
Aaqil_Jamal
Allowing to embed links in Behance is helpful but it would be great if it’s taken to the next level.
Currently, once you embed a link on Behance, you can scroll down and view the design, even clicking prototype works like a charm. One issue I’ve faced is in embed view the prototype doesn’t allow clicks that take the person outside of Figma. I created a case study in which I added links to my research captured in Google Docs thinking it would take the user there if clicked but anything that takes the user out of the Figma link doesn’t work. If we can fix this it would be great as we won’t have to add images on Behance and my case study could become more lively and easily managable.
Thanks
Gayani_S
  • 2131 replies
  • January 17, 2024
Hey Aaqil, I am able to link a Google doc. Would you be able to share a screen recording with us?
Hi there! I’m experiencing the same issue as Aaqil. I’ve designed and built my portfolio in Figma, and I’ve embedded it on Behance to be easily seen by recruiters. But every single link I added, that leads to an external source, is unresponsive. They are seen as clickable, but nothing happens when you click on them.
It would be great if you could fix this, making Figma even more awesome than it already is 🙌🏾
Gayani_S
  • 2131 replies
  • January 23, 2024
Hey Frank, thank you for your feedback! Is this happening only when you embed your Figma file to Behance? Have you tested these link before embedding there?
  • January 31, 2024
Hi there! I’m facing the same issue as Aaqil and Frank. All my links to external sources work in the Figma prototype. Nevertheless, If I embed them on Behance they’re seen as responsive and interactive, but nothing happens on click. 😞
Aaqil_Jamal
  • 4 replies
  • February 12, 2024
Hi Gayani.
Sure, sharing the video attachment here for reference.
The video shows the click of the Google Doc link from Figma’s Prototype space vs the Embedded link used on Behance.
Let me know if this helps.
Thanks
Gayani_S
  • 2131 replies
  • February 13, 2024
Hey @Aaqil_Jamal, thanks a lot for sharing this screen recording with me! I understand now your frustration. Let me share this internally and see if there are any solutions for this. I’ll give you an update once I receive a response. Appreciate your patience!
Gayani_S
  • 2131 replies
  • February 26, 2024
Hey everyone, apologies for the delayed response!
Can you confirm if you’ve embedded a link directly to a specific frame or if you’ve linked it to the overall file?
Also, please confirm that you’re embedding URLs that look like https://www.figma.com/file/LKQ4FJ4bTnCSjedbRpk931/Sample-File and not like https://www.figma.com/file/LKQ4FJ4bTnCSjedbRpk931/Sample-File?node-id=1-497?
Thank you in advance!
Hi was there a resolution to this issue? I am facing the same problem. the link (in a frame) opens from Figma, but not from behance.
hi still waiting for a response.
Gayani_S
  • 2131 replies
  • August 7, 2024
Hey @Nikita_Raveendran, apologies that I’ve missed your comment. I’ve double checked this with the team and they’ve asked to confirm the following to investigate further:
U have a solution???
Any solution? I cant open links in Behance but in Figma yes
Gayani_S
  • 2131 replies
  • August 12, 2024
Hey @Emiliano_Ostertag, thank you for reaching out! Can you please check my previous reply. I would need this information so the team can investigate further.
Adrian_Cerbaro
Hello, I have a similar issue.
I’m trying to embed a FigJam in a web page, but the links to other nodes in the file don’t work, only external links. The links to other nodes work when I open the file directly in FigJam.
I am using the link as you mentioned (without any node selected).
emi.rusakova1
Hello. I have the same problem. I tried to insert a link to my Telegram in a button in the Figma prototype. It works within Figma, but it doesn’t click on Behance when using the embedded code.
CHIARA COSTA
Hello everyone, I’m having the same issue. Any solutions?
Thank you
rashmi.koushik
Hello. I am facing the same issue! I’ve designed and built my portfolio in Figma, and I’ve embedded it on Behance. The links work on edit mode. But soon after the project is published, they don’t. Not sure how to change the url as described in the comments to make it work. Please suggest.
avnipal
  • July 7, 2025
Hi, I am facing the same issue and the problem has not been resolved yet.
