Shawn_Willings
Sep 29, 2023 5:12 PM UTC
Additional Boolean Variables - Seperate visibility of fills/strokes/effects
It would be great to be able to seperate the visibility objects beyond just the layer. To be able to associate a boolean variable to the visibility of;
  • Layer
  • Fill
  • Stroke
  • Effects
Would make it more effective when putting together a design system. This means that you could effectively determine that all buttons have outlines, or drop shadows or both right across the whole design.
See examples below.
Thoughts?
Aleks
May 6, 2024 11:54 AM UTC
Good idea.
Pavel_Kiselev
Power Member
May 6, 2024 12:42 PM UTC
You can do it right away with layers though
Nik3
Jun 13, 2024 11:54 AM UTC
Yeah but it’s redundant. It would be way less data, if i give e.g. the button frame a specific border, filling ,radius (and the visibility of the border for example) all connected to variables. so that i only have to configure the stuff on the button frame not sublayers 🙂
Pavel_Kiselev
Power Member
Jun 14, 2024 7:47 AM UTC
All true, indeed. However if you need things done today layers to the rescue. Another thought is that you make button once and move on, not a big deal. If you want to optimize the process you can separate visual layer into reusable style components
The concept explained here → Making of true multi-brand design system | by Pavel Kiselev | UX Collective, check under “Component styles” section
And if you want to see some live examples I have community file for you → https://www.figma.com/community/file/1372632073691205444/source-ds-forms
AntoinePuig
Oct 7, 2025 6:09 AM UTC
+1, much needed
marmatsan.dev
Jan 12, 2026 11:00 PM UTC
Waiting for this
artichokes
Feb 5, 2026 10:45 AM UTC
Also waiting for this
