mkippenberger
Mar 26, 2024 11:35 AM UTC
Ability to prototype non-variant property changes
Currently, you can use prototyping features to change between variants of a component via the “Change to” interaction. However, a component may have properties other than variant properties, i.e., boolean, text, and instance swap. I would like to be able to modify these properties, too, when prototyping.
For my specific use case, I have a component with a boolean property that toggles the visibility of a child element. I realize that I could turn this boolean property into a variant property and be able to prototype the desired interaction via “Change to”. However, this would double the number of variants that I have (each existing variant in the off/false state and in the on/true state) which is not desirable, especially if you’re working with several boolean properties and the number of variants will grow exponentially.
