Petr_Chutny
May 27, 2021 12:37 PM UTC
When using an interactive component in a prototype, "Click" doesn't execute
Hello,
I have created a “Button” component with a hover state. It uses “mouse enter” in order to “change to” its hover variant.
When I use such button in my design and add “click” prototype interaction to show an overlay, nothing happens on click:
Prototype:
CleanShot 2021-05-27 at 14.36.29
After deleting the variant interaction from this instance, the good old “click” actually works:
Prototype:
CleanShot 2021-05-27 at 14.37.04
Andrew_Chan
Andrew_ChanSolution
Oct 19, 2021 8:11 PM UTC
Hi @Jorge_Lozano_Cerrato @Su1 this actually sounds like a big bug. Can you DM me your file or let support know that we’d like to escalate this? You can cc achan@figma.com and invite the same email to the file to make sure I have access. This’ll help us figure it out faster.
Thanks!
jhalak_doshi
Jul 24, 2021 6:24 PM UTC
Try connecting the component with the frame with on click trigger and the original one with the while hovering, might work out…did work for me.
Su1
Sep 3, 2021 12:04 PM UTC
I had the same problem! You simply need to use “Mouse Up” instead of “On Click” 🙂
Oct 17, 2021 10:17 AM UTC
I don’t know why some thing as important as click event doesn’t work… And @anon21722796 didn’t anything to fix it?
I tried Figma for the first time but I deeply regret… I would have used Adobe XD for my prototype as always… Now I don’t have time to remake it…
Andrew_Chan
Andrew_ChanSolution
Thanks!
malicia
Oct 27, 2021 9:32 AM UTC
Hi Andrew, I have the same issue: the mouse up event in the interactive variant overrides the click in a prototype. I am trying to add hover states to buttons on a library (with mouse enter, down and up etc), but once that is in place, existing prototypes that contain buttons stop working.
Paul_Van_Tuyl
Nov 1, 2021 8:31 PM UTC
Hi @Andrew_Chan, I have also found that various variant interactive states override each other and they override frame interactions.
Here is a basic test that took me about 5m to set up: Figma
Tomas_Marek
Nov 8, 2021 2:22 PM UTC
Yes it is not a happy issue, but I am using a simple “hack” - instead of using “Click” you can use “Mouse down” and this is an easy working solution.
Patrick-Plaggenborg
Jan 10, 2022 1:42 PM UTC
Looks like a bug indeed. @Andrew_Chan @anon21722796 this has not been solved yet. I still have the same issue.
The Interactive Component contains interactions between variants to simulate a button press down:
  • Mouse Down
  • Mouse Up
When using an Instance of that component in a Prototype I want to add a ‘Click’ interaction to simulate the action upon button click.
Problem:
  • The Click interaction is ignored
Workaround:
  • Use Mouse Up instead of Click in the prototype
This works, but has the side effect that clicking and holding anywhere outside the Instance and then releasing (Mouse Up) with the cursor over the Instance will also trigger Mouse Up.
Does not happen often but can cause confusing and makes Mouse Up a hacky workaround.
Expectation:
  • Click = Mouse Down with cursor on Instance, then Mouse Up while on that same Instance
  • Mouse Up = Mouse Down anywhere on the screen, then Mouse Up while on the Instance you set the interaction for
Would love to see the proper Click interaction fixed as this is broken now.
Satu_Himanen
Feb 14, 2022 10:45 AM UTC
Hi! It’s been a year now, when will this bug is being fixed? Now even the mouse up etc. won’t work.
Jakub_Bartasek
Mar 2, 2022 1:04 PM UTC
Instead of Mouse Down, use While Pressing
