Lorem-Possum
Nov 27, 2023 8:53 AM UTC
Vertical transition/animation cropped in component instance
Hi,
here is the example file: https://www.figma.com/file/AiYlhJZEIXMnLqZkF0rIj6/instance-bug?type=design&node-id=0%3A1&mode=design&t=EpBK27WgZu0y2aTv-1
Try to run prorotype flow 1 and flow 2
flow 1 is for instance of component
and flow 2 is for detached instance
First case - vertical transition/animation is croped
And second case - it works properly.
Nov 28, 2023 1:09 AM UTC
Hi there,
Thanks for reaching out and the link. That was helpful for me to understand the issue. This is unfortunately a feature limitation where swapping instances/changing variants on nested instances keeps the size of the initial instances/variant. There is a workaround for it.
To get the nested instance to resize, you can add auto layout on each variant. I attached my video for you.
I hope this helps. We will continue to improve the products with your opinion! Thanks for flagging.
Toku
Lorem-Possum
Nov 28, 2023 8:45 AM UTC
Thanks, it works
