Underline text on hover not working?
SLT-UX
This should be very simple:
  1. I have a component with 2 variants. Variant1 has a text layer which is not underlined text, and Variant2 has the same text layer (same layer name of course), which is underlined text.
  2. I added a hover interaction on Variant1 to change to Variant2
When I test it out in the prototype, the underlined text doesn’t show up on hover.
To make sure the variant switch is happening on hover, I changed the background of Variant2, and sure enough, the background change does happen on hover.
So for some reason the text underline is just not happening.
This is a bug, right?
Any workarounds?
Best answer by KennLucas
Oh hey!
I just stripped the text style off of my text and the variant hover works with no variables on my text.
So there is a conflict somewhere.
But unstyled text works!
KennLucas
This has to be a new bug. I just had this start happening to me today and I KNOW they were working as recently as yesterday.
KennLucas
Oh hey!
SLT-UX
  • Active Member
  • July 18, 2024
@KennLucas Thank you! I had given up on it. Yep you figured out the issue: Some issue with Text Styles (color styles are OK).
@dvaliao can you please forward this bug to the team?
  • July 18, 2024
Thanks for looping me in!
The team is already aware, but I’ll be sure to send over this topic for more context.
Lloyd2
  • September 17, 2024
Confirmed as not working for me building breadcrumbs with “While hovering” interaction and a text style applied with a nested component.
Nathaly_Mateo_Pena
Hello did anyone find a workout about this?
Tobias3
  • November 13, 2024
I have the same problem. Underlined font working very randomly. Typeface used is Avenir Next. Please see below - six of the same component, where two out of six show the underline. Super-buggy.
I truly love Figma, but this is just way off. I have read several articles - some as old as 2021 with people who seem to have similar problems with underlining text. I´d be very greatful if somebody at Figma could look into this and get back to me.
Thank you kindly
/T
Tobias3
  • November 13, 2024
I found a workaround. When I removed the text-style from the headers, i got it to work. I mean clearly it should work anyway, but for now, that worked 👍
Cassidy
  • November 19, 2024
I am also currently having this issue. My text styles have also been detached and the underline on hover still isn’t working. Has there been an update to this?
Cristiane
  • February 4, 2025
I’m also having the same issue, there are no styles applied, but still doesn’t work. Other settings like changing background work, so it’s not the component. Thanks.
  • February 6, 2025
Hi ​@Cristiane ,
Thanks for reaching out. Could you share the video recording? I couldn’t replicate this with or without styles.
Toku
Stefan Tomic
If your component is defined like this:
  • Link – default
  • Link – hovered
  • Link – pressed
And you defined certain font size of the component.
Each time when you change the font size or the text value of the component, the text-underline style is not working. It will only work when the text value is “Link” and the font size is the default one that is set on the component.
I don’t know the solution to this issue, but maybe now somebody has an idea what it could be?
