Underline Superscript Marks Doesn't Work
  • February 19, 2025
  • 51 views
Cristofaro_DiNoto
When underlining a text button, the registration mark or other marks don’t underline properly. The new offset feature also doesn’t fix this issue. Is there a way to underline the baseline of the text layer instead of the characters?
ScottDaniels
  • 14 replies
  • March 11, 2025
@Cristofaro_DiNoto
I found a hacky solution for this by simply using strike-thru instead. Superscript the content, then apply strike-thru. This works as a visible solve but more work for designers to explain it to developers who refer to specs in DevMode.
  • The Figma team should fix the offset to work for actual superscripted links.
  • They should also make it so we can apply effects like superscript to text with styles applied without detaching.
