Unable to embed Figma design from a branch
  • April 18, 2025
  • 26 views
DJ_Sargent1
When I generate an embed code from the Figma design view, the embed iframe displays the Figma design correctly, but if I generate a embed code from the branch of the same file, the embed iframe loads a blank page. Prototype embed code from the branch file works correctly, it’s the design embed code that does not work. Is this a bug, or is this not supported?
  • 2545 replies
  • April 22, 2025
Hi ​@DJ_Sargent1
Thanks for reaching out. Just to confirm, are you using the embed code from the Share button?
Also, have you checked if the permissions are set correctly? If the permissions are limited, the file might not load the correct image.
If the settings are correct but the preview isn't loading properly, could you please submit a bug report detailing the steps that led to this issue? You can do so by following this link: Submit a Bug Report.
I hope this helps!
Toku
