The issue where the height value automatically changes from "Fixed" to "Hug" when combining duplicated components to apply a nested instance.
  • April 13, 2025
  • 25 views
teo.kang
I want to solve the issue where the height value automatically changes from "Fixed" to "Hug" when combining (click create component set) duplicated components to apply a nested instance.
That issue actually occurs even before applying a nested instance—just grouping the components triggers it. When I manually change the height from "Hug" to "Fixed" after combining the group, the size options defined in the original parent component no longer work as intended.
[before combine components]
buttons height is fixed (56)
[after combine components]
buttons height state is change with hug
Raphael_M
  • 394 replies
  • April 14, 2025
I’m wondering where did your padding go? I think the instance was wrapped again so you can make it into another component. Check your layers
