Subject: 🚨 Dev Mode Not Loading Code (Tried All Possible Solutions)
  • February 24, 2025
  • 4 replies
  • 258 views
Viktor Stovpets
Issue Description:
Hello, I’m experiencing an issue with Dev Mode in Figma: it has stopped loading code, even though it worked fine before. No matter which code type I select (HTML/CSS, React, Swift, etc.) in the Dev resources β†’ Code panel, the field remains empty.
Key observations:
  • The loading indicator spins, but in the end, the code section remains blank.
  • I have tried different Dev Mode plugins (e.g., Figma to Code, Figma Tokens, etc.), but none of them load the code.
  • I switched between different code types (HTML, React, Swift), but nothing changes.
I have already tried all possible troubleshooting steps, but nothing has worked.
What I Have Already Tried:
βœ… Checked Figma’s status β†’ https://status.figma.com/ (everything is operational).
βœ… Created a new project in my workspace β†’ Dev Mode does not work even in a fresh file.
βœ… Tried different Dev Mode plugins β†’ none of them display any code.
βœ… Opened Figma in different versions:
  • Web version (Chrome, Edge, Firefox) β€” Not working
  • Incognito mode β€” Not working
  • Desktop app (Windows) β€” Not working
βœ… Cleared Figma’s cache (both desktop and browser):
  • Manually deleted the AppData/Roaming/Figma folder
  • Cleared cache via Preferences β†’ Clear Cache
  • Used Ctrl + Shift + R and cleared cache in browser settings
βœ… Disabled and re-enabled Dev Mode β€” did not help.
βœ… Logged out and back in, tried a different device β€” issue persists.
βœ… Tried logging in from another account β€” Dev Mode also does not work on a different account.
βœ… Checked workspace permissions β€” I have a paid Professional Plan with full file access.
βœ… Tried using Dev Mode with different files and components β€” code does not load in any of them.
Additional Details:
  • Plan: Professional Plan
  • Seats: 1 Full Seat (Design + FigJam)
  • Billing status: Active, account is not restricted
  • Browser: Chrome / Edge (latest versions)
  • OS: Windows 11
  • Figma Desktop: Latest version installed
Screenshots attached.
Expected Behavior:
Previously, when enabling Dev Mode, I could see the code for any selected element. Now, the code section remains blank even in new files, different browsers, and with different plugins.
Please investigate the possible cause and suggest a solution. Could this be a bug in the latest Figma update?
Thank you!
Tim Riley
  • February 27, 2025
I’ve been experiencing the exact same issues and have not been able to resolve.
Ratgy
  • February 28, 2025
저도 λ™μΌν•œ 문제λ₯Ό κ²ͺκ³  μžˆμŠ΅λ‹ˆλ‹€.
  • Figmate
  • 2382 replies
  • March 3, 2025
Hi ​@Viktor Stovpets, Thanks so much for letting us know and for trying to troubleshoot!
I haven't been able to see the problem on my end yet, but we know this can be a real pain, and we want to help this for you. I'll go ahead and created a support ticket with the info you gave us.
Our support team will reach out to you soon. Keep an eye on your inbox for an email about the ticket, it'll go to the email address on your account.
Upon receiving the ticket notification, please reply with the following information to aid in our investigation:
If anyone else experiencing the issue after trying all the troubleshooting steps mentioned by ​@Viktor Stovpets  please help submitting a bug report using this guide: Submit a bug report
A video and clear steps to recreate the problem are super helpful for us.
Thank you once again for your cooperation.
Alessandro Morelli
Dev mode stopped showing proper code recently, whenever there is a svg or icon present (for example from lucide library) it doesn’t work. If I select every other div/section except the one with the icon those work fine.
