Vitaly_Gachkovsky
Nov 27, 2023 8:20 AM UTC
ReferenceError: regeneratorRuntime is not defined
Hello! I am developing an interactive plugin with asynchronous functions, and suddenly when I ran the development file I received a error I didn’t see before: ReferenceError: regeneratorRuntime is not defined. Here’s the full error code:
    at eval (eval at <anonymous> (eval at createScopedEvaluatorFactory (1d4564d8-5e8b-4125-a68a-5dfbedf1e353:1:1)), <anonymous>:3:20)
    at ./node_modules/@babel/runtime/regenerator/index.js (VM1251 PLUGIN_5_SOURCE:548:44)
    at __webpack_require__ (VM1251 PLUGIN_5_SOURCE:20:30)
    at ./src/plugin/controller.js (VM1251 PLUGIN_5_SOURCE:857:84)
    at eval (VM1251 PLUGIN_5_SOURCE:84:18)
    at Proxy.eval (VM1251 PLUGIN_5_SOURCE:87:10)
    at Object.eval (eval at createScopedEvaluatorFactory (1d4564d8-5e8b-4125-a68a-5dfbedf1e353:1:1), <anonymous>:8:16)
    at 1d4564d8-5e8b-4125-a68a-5dfbedf1e353:9:1235
    at 1d4564d8-5e8b-4125-a68a-5dfbedf1e353:9:1908
I googled this problem and tried every possible solution:
  1. reinstaling @babel/preset-env@latest @babel/plugin-transform-runtime@latest core-js@latest
  2. checking webpack and babel configuration
  3. restarting terminal, Figma, and my laptop
But nothing works – I can see runtime-generator function in my compiled entry code.js file but the error persists. I also asked chatGPT and followed its advice but nothing helped. I think the problem might be in the Figma environment.
Here’s my Babel configuration:
  "presets": [
      "@babel/preset-env",
        "useBuiltIns": "entry",
        "esmodules": true,
        "corejs": { "version": 3, "proposals": true },
        "targets": {
          "node": "current"
    "@babel/preset-react"
  "plugins": [
      "@babel/plugin-transform-runtime",
        "regenerator": true
Webpack.config:
const HtmlWebpackInlineSourcePlugin = require('html-webpack-inline-source-plugin')
const HtmlWebpackPlugin = require('html-webpack-plugin')
const path = require('path')
module.exports = (env, argv) => ({
  mode: argv.mode === 'production' ? 'production' : 'development',
  devtool: argv.mode === 'production' ? false : 'inline-source-map',
  entry: {
    ui: './src/app/index.jsx',
    code: './src/plugin/controller.js'
  output: {
    filename: '[name].js',
    path: path.resolve(__dirname, 'dist') // Compile into a folder called "dist"
  module: {
    rules: [
        test: /\.jsx?$/,
        use: {
          loader: 'babel-loader',
          options: {
            presets: ['@babel/preset-env', '@babel/preset-react'],
            plugins: ['@babel/plugin-proposal-class-properties', '@babel/plugin-transform-runtime']
        exclude: /node_modules/
        test: /\.js$/,
        use: {
          options: {
        test: /\.s[ac]ss$/i,
        use: [
          // Creates `style` nodes from JS strings
          'style-loader',
          // Translates CSS into CommonJS
          'css-loader',
          // Compiles Sass to CSS
          'sass-loader'
      { test: /\.mjs$/, include: /node_modules/, type: 'javascript/auto' },
      { test: /\.css$/, use: [ 'style-loader', 'css-loader' ] },
      // Allows you to use "<%= require('./file.svg') %>" in your HTML code to get a data URI
      { test: /\.(png|jpg|gif|webp|svg)$/, loader: [{ loader: 'url-loader' }] },
        test: /\.(ttf|otf|woff|woff2)$/i,
        loader: 'file-loader',
        options: {
  // Webpack tries these extensions for you if you omit the extension like "import './file'"
  resolve: { extensions: ['.tsx', '.ts', '.jsx', '.js', '.mjs'] },
  // Tells Webpack to generate "ui.html" and to inline "ui.ts" into it
  plugins: [
    new HtmlWebpackPlugin({
      template: './src/app/index.html',
      filename: 'ui.html',
      inlineSource: '.(js)$',
      chunks: ['ui']
    new HtmlWebpackInlineSourcePlugin()
