Getting the “Publishing failed: Please reload the page to publish” error when I try to publish.
I’ve gone through the older treads but haven’t found a solutions beside Figma sent out a fix. I’ve tried everything I can think of including the obvious solutions like reloading tab and restarting computer.
I’ve tried deleting all new components and even restored earlier versions, from the version history panel, that were previously published. Yet still no luck. My other libraries will publish, but my main library will not. 🙄
I have a component library that I has previously been published. I am trying to publish it again with more changes, but after clicking the publish button it says "Publishing failed. Please reload the page to publish".
I have tried reloading, I have tried rolling back to a version that was successfully published, I have tried publishing from the web client instead of the app, I have tried publishing one component at a time, and even tried to unpublish the library, which also didn't work.
Anyone ever had this happen before? I'm tearing my hair out.
Same here. It’s only happening to 1 library that’s quite big strangely. I reverted back to when the library was previously publishing and even back to when the file was first created but still getting the failure error.
I have a problem with figma file when publishing my library. I have closed and reopened the file and figma many times but still have this problem. It affects the progress of my project. Please fix it quickly.
Hey everyone, thank you for your patience while the team was investigating this issue!
Our engineering team have deployed a fix for this issue now, can you please refresh the browser/restart the Figma app, and check if publishing is working for you now?
Apologies for any disruption that was caused by this - please do let us know if you experience any issues when trying to publish now.
Thanks for checking in here, @Kevin Tang — and sorry to hear you're running into trouble.
From what I can see, the issue you're encountering may be related to a separate one that the team is currently investigating. Our Technical Quality team is looking into your report and will follow up via the email address linked to your account.
Appreciate your patience — keep an eye out for updates there!
Hi, I’m getting this error for the past 24 hours as well. Anyone having the same issue again?
I’ve tried everything I can think of including the obvious solutions like reloading, restarting, reverting to older versions etc. Components don’t seem to have any conflicting layers or naming. Could there be another bug?
Hey @Rebecca Werres , thanks for sharing what’s happening. We’re not aware of a current bug causing this, so it may be a separate issue that needs further investigation.
I see you’ve already reached out to our Support team, and your case (for reference, case #1534246) has been escalated to the technical quality team. The best next step is to continue the conversation there and share any additional details they request. That way, they can take a closer look and get to the bottom of the issue directly.
Sharing an update here for visibility: I can see in the backend that you mentioned to the Technical Quality team that the issue seems to have resolved itself over the weekend. Thanks for letting us know!
For visibility, we’re not aware of any specific fixes released during that time that could explain this publishing issue. We apologize that we don’t have a clearer root cause to share at the moment.
Our team will continue monitoring in case anything broader comes up. For anyone else experiencing similar behavior in future updates to this file or other libraries, please submit a bug report here so our support team can investigate more quickly. Thank you for your understanding 🙏🏼
Page 1 / 1
I’m experiencing the same issue, tried different things but no luck.
Our company is facing the same issue. :-(
I’m also facing the same issue.
Hi there, Thanks for reporting this!
This might be related to an ongoing bug that our team is already aware of. Once we have more details on this, we'll be sure to update.
We really appreciate your patience as we work on this.
Me too. I can't be calm right now. 🙄
Tried updating this morning was able to successfully publish. Hopefully this issue is resolved. Anyone else able to successfully publish?
I am still having this issue.. reached out to Figma support.. but no news yet.
Has anyone got any updates on this? I am still unable to update/publish. Is it working for you?
Having the same issue ! I thought it was only me !
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
