I have two component’s in my prototype.
BUTTON COMPONENT
A typical button with props for state=[resting|hover], text={string} and Icon={string}.
It changes states with “while hovering” interaction and updates it’s state prop from resting to hover.
The hover state has different fill and stroke, so while hovering the button changes design.
Pretty standard button stuff.
SHOW MORE COMPONENT
A section off truncated text that can be expanded to view the full text.
It has props content={string} and state=[open|closed]
The component has a nested BUTTON the user can click on the toggle READ MORE’s state between state=open and state=closed.
Depending on state=[open|closed] the instance of BUTTON will have different values for text and icon, i.g.:
expanded=truehasbutton[text="less", icon="minus"]expanded=falsehasbutton[text="more", icon="plus"]
THE PROBLEM
In my prototype the BUTTON props are fixed to whatever they were on first render.
BUTTON will not update new values for text or icon when SHOW MORE changes states form open to closed. If I remove the “while hovering” state from BUTTON it works as intended, so my guess its something to do with interactive components inside interactive components.
THINGS I’VE TRIED
- Resetting component state on change of state in component (no change in behavior)
- Changing “while hovering” to “on enter”/“on exit” (no change in behavior)
- Naming BUTTON different things in state=open and state=closed (this fixes the prop issue but breaks the animations)
