Alexander Wilson
Oct 24, 2025 1:56 PM UTC
Remote Figma MCP doesnt work with Amazon Q
When attempting to add the configuration with Amazon Q, the startup process fails due to a non-200 status code. This might be related to Figma’s login requirement, though I’m not certain. I’ve followed the setup instructions outlined in the Figma MCP Server documentation: https://developers.figma.com/docs/figma-mcp-server/remote-server-installation/. However, the documentation does not reference Amazon Q specifically, which suggests that this client may not have been tested yet. For context, I’ve been able to successfully connect to the local version of the MCP Server using Amazon Q.
Has anyone gotten this working?
Can the Figma team please test with Amazon Q and provide directions about how to proceed? Amazon Q is the offering that our company has chosen to use and many developers are running on Linux machines. This means that their only way to access the MCP server is via the remote option which is currently unavailable to them.
ksn
ksnSolution
Oct 27, 2025 5:48 PM UTC
Hey both - we are continuing to explore our offerings, but at this time, Amazon Q is a 3rd party MCP server. With this is mind, my best recommendation is to reach out to your contacts at Amazon Q, and encourage that they begin an interactive process with us on becoming supported.
I did inquire about this internally and made note that you’d like to see this supported in the future. Thank you for your understanding.
Alexander Wilson
Oct 24, 2025 3:25 PM UTC
For more detail about the Amazon Q client we use with VSCode, here is a link: https://marketplace.visualstudio.com/items?itemName=AmazonWebServices.amazon-q-vscode
Mike at Code and Theory
Oct 24, 2025 4:12 PM UTC
I am getting the same error using Amazon Q.
ksn
ksnSolution
Alexander Wilson
Nov 5, 2025 3:38 PM UTC
Hey KSN, Thanks for your response. I'd like to clarify the technical setup to ensure we're aligned on the issue.
Amazon Q functions as an MCP client that connects to various MCP servers, rather than being an MCP server itself. The challenge we're encountering is that Figma's MCP server doesn't appear to be compatible with Amazon Q as a client, despite Amazon Q working successfully with other MCP servers.
Given that this seems to be a compatibility issue between Figma's server implementation and Amazon Q's client interface, I believe the most effective path forward would be for Figma's team to investigate and address this directly. As end users, we're limited in our ability to facilitate technical discussions between organizations.
I'm certainly willing to assist with testing and feedback throughout this process.
kevo1ution
Nov 12, 2025 5:16 AM UTC
there’s a very similar issue with the Figma MCP remote server and Firebender
the client seems to need access to the right OAuth scopes
JP112
Jan 19, 2026 6:26 PM UTC
Aer you saying here that you were indeed able to set up a local version?
“For context, I’ve been able to successfully connect to the local version of the MCP Server using Amazon Q”
If so How did you do that?
