Issues with Stroke, Fill and Auto layout functionality
Inna Ramashko
Hi Figma team,
I wanted to share some persistent issues I’ve been experiencing for over a month now related to Stroke and Fill functionality.
Stroke issues:
I often can’t remove the stroke or set it to appear on only one side. This is especially problematic when the object is nested within another frame.
Fill issues:
The “+” button to add a new fill works only occasionally. While clicking on the Fill area does trigger a response from the system, actually adding or deleting a fill rarely works. Often, I have to just toggle the visibility (“eye” icon) off — even if I know I won’t need a fill at all — because I simply can’t delete it.
Spacing/padding issues (new):
As of today, I’m unable to set different paddings for different sides of an object. It only lets me set a uniform value for all sides, and the option to adjust each side individually appears to be missing or broken.
These bugs are impacting my workflow significantly. I’d really appreciate it if the team could take a look.
Thanks so much!
Lukas Russell
Same thing is happening to me!! Can’t add stroke of fills to frames using + or pre-created styles. Super frustrating
Lukas Russell
I dragged the right side of the Figma window off of the side of my monitor by about 240px and that seems to have solved the problem. Weird!
