[FIXED] Jira widget - lost all designs links attached to tasks
Klaidas
Today we experienced a complete detachment of Figma links in Jira tasks. We believe it could be a culprit of Jira widget in Figma. Did anybody encountered the same thing?
Best answer by Junko3
Hello there, We've received confirmation from Atlassian that a fix for this issue has been released.
Please refer to this Jira Incident Report page: https://jira-software.status.atlassian.com/incidents/gq93w4gfvy44
To apply the fix, please try refreshing Jira.
Thank you again for your patience and understanding.
Simon Jun
  • January 23, 2025
Yep same problem with our connections, everything is gone.
Klaidas
  • 4 replies
  • January 23, 2025
We went to reuploading the links to Jira as Web links, hoping that it will hold better than Design links.
Simon Jun
  • January 23, 2025
We are doing the same and adding them inside the description as well, just to be sure.
Lilito
  • January 23, 2025
For us the same experience, suddenly the links dissapear.
Mohamed Abdelwahed
It seems not only us, the whole links got detached...any think I should do?
Thomas_
  • January 23, 2025
This week our team started using the Figma for Jira app. For a few days the plugin worked as intended and we were able to add various designs to our stories. However when I checked those stories today the design that were place there are gone.
The plugin is still active and I can add designs, however when I try to interact with the design or refresh/reopen the story, the design disappears. After checking with our Jira admin we discovered that the plugin keeps disconnecting itself from our Figma team after we give it permission.
As of now all the designs that were linked to a story are gone and the plugin doesn't stay connected long enough to add them back. I would love to know if there is a solution to this problem since the plugin was a great improvement to our workflow.
Klaidas
  • 4 replies
  • January 23, 2025
@Mohamed Abdelwahed - use Web links in Jira and/or add URL’s to Jira’s task description.
Hopefully, this will get fixed, cause for now we’re not planning to use Jira’s widget due to waste of time today we’ve encountered..
Mohamed Abdelwahed
Thank you ​@Klaidas  Do u think they could relink the the tickets again? the missed ones
Klaidas
  • 4 replies
  • January 23, 2025
Yeah, something went south with the Widget, cause we had to reattach all links. I raised this problem already here in case you want to follow up.
Klaidas
  • 4 replies
  • January 23, 2025
To be fair with you I have my doubts, I don’t think is feasible from technical standpoint. I would recommend for you to reattach them manually for now and let’s hope this bug will get noticed and fixed for later widget use.
Erik Mathijs
We have the same problem with our instance.
I hope the data is not deleted in Jira and it will be solved by a new release of the Figma app.
If all design files are detached it should be a huge problem in our company
Mohamed Abdelwahed
@Erik Mathijs  Same same :(
  • 3688 replies
  • January 23, 2025
Hey everyone, thank you for flagging this!
Our engineering team is aware of the issue and is actively investigating. We appreciate your patience in the meantime 🙏🏼
sam.chidambaram
Yes the same issue ; it has removed all the links and any new links also are not seen
John Fitzgerald
Just adding a Me Too to this thread. All Figma links are gone and re-adding them looks like it works but then they disappear if you interact with them or refresh the page.
Tom Hudson
  • January 23, 2025
@Klaidas I’m curious whether all your relinked designs stuck?  Our experience is that as soon as you refresh a Jira ticket after you’ve added a design, the design disappears again.  Would be lame if you did all that work just to have to do it again whenever this problem is fixed permanently.
Mohamed Abdelwahed
  • Figmate
  • 2114 replies
  • January 24, 2025
Hi there, we wanted to share an update that our team has escalated this further with Atlassian and they are continuing to work to get this resolved as soon as possible.
From the investigation so far, we want to clarify that no data loss has occurred for any Design links in existing tasks.
However, there is an ongoing loading issue in Jira preventing the Design panel and linked files from being displayed as expected. We will continue to share updates on any fixes as soon as they become available.
We appreciate your cooperation and patience!
  • Figmate
  • 2114 replies
  • January 24, 2025
