Paul_Soultis
Mar 7, 2024 6:01 AM UTC
FIXED: Bug with Multi select / edit text and library font styles
Hi team,
With the new multi select/edit text, when using this function across different breakpoints the fonts styles are being replacedto match the edited field.
If the edit prompt field is in a desktop frame it will replace our mobile frame with the same desktop font styling.
Is there a way to make edits to the copy without the styling being replaced?
Paul_Soultis
Paul_SoultisSolution
Mar 18, 2024 11:13 PM UTC
Hi @Celine_Figma it looks like a fix was deployed and the multi-edit is working without changing the font style.
Thanks for the support!
Mar 8, 2024 11:43 AM UTC
Hey Paul! Thank you for your feedback. This is intended for now, but we will pass your feedback to the team for improvement!
Paul_Soultis
Mar 11, 2024 3:26 AM UTC
Thanks, @Celine_Figma appreciate the response. Would you happen to have a shareable roadmap of what the intention will be in the future?
Also, can you suggest any temporary workarounds after a multi-select-edit to prevent font styling changes without the need to manually change the text fields for the mobile breakpoints back to the mobile-specific font style?
Thanks
Paul
Mar 11, 2024 2:23 PM UTC
Hi Paul! To be transparent, the team is working on it now to implement a fix, although it is an “intended” behaviour - while I can’t share any specific ETA for the moment. Stay tuned, and thanks for your patience in the meantime! 🙏
Paul_Soultis
Mar 11, 2024 11:02 PM UTC
Thanks for your transparency @Celine_Figma. I’ll keep an eye out for the fix.
Paul_Soultis
Paul_SoultisAuthorSolution
Mar 19, 2024 10:45 AM UTC
Hey Paul!
Yes, I confirm a fix has been deployed. Thank you for following up!
