Figma Site keeps failing to publish after reaching a certain number of attempts.
Naye
  • 4956 replies
  • May 8, 2025
Hi ​@Naye, thanks for flagging this!
Can you please send a file link to our support team here? https://help.figma.com/hc/en-us/requests/new
Our team can dig into what’s causing this for you.
Surakiti
  • May 9, 2025
I’m having the same issue as you. I’ve tried deleting everything, but the problem still persists.
Naye
  • May 9, 2025
I’ve encountered this issue with two files. I calculated that after about 50 publishes, the problem starts to occur.
Surakiti
  • May 9, 2025
I’ve tried creating a new file and copying only the design into it, but I still can’t publish.
The system still shows that publishing is not possible. TT
  • 4956 replies
  • May 9, 2025
Hi All, thanks for following up!
Just as I suggested for ​@Naye, can you please send a file link to our support team here? https://help.figma.com/hc/en-us/requests/new
Our team needs to take a look at the backend of Sites to find what’s causing this for you on a case by case basis.
Naye
  • May 9, 2025
I’ve submitted the issue and  link, and I’m still in communication.
Ionutss
  • May 11, 2025
Having the same issue, tommorow I’m supposed to present a figma sites design using an URL, this kinda sucks :)
Jocelyn3
  • 4 replies
  • May 12, 2025
Having the same issue, but already on the first publish attempt.
Abdulqadir Rampurawala
Facing the same issue. Site just won’t get published. I’ve moved my entire portfolio on Figma site and sent link in applications. But I’ve made few key updates which are not getting published.
More over it does not even give what error is caused in publishing. So it’s frustrating
Jocelyn3
  • 4 replies
  • May 15, 2025
FYI I fixed the issue in my case and am now able to successfully publish.
Apparently it had to do with a faulty vector component with uncommitted boolean operations in it from a library I imported into Sites. When I rebuilt the component cleanly and flattened all vectors, I was able to publish my site.
