waqarnaik
Oct 1, 2024 6:54 PM UTC
🔴 👉 Figjam connector Bug when used in Figma
I was trying to connect 2 shapes with the connector that I copied from FigJam and noticed that the connector only attaching on the left side of the shape end or on any objects in Figma. please let me know if im doing anything wrong or is this a bug. Please help!!!
Figma_IPrtegwddX
waqarnaik
waqarnaikAuthor
Oct 2, 2024 5:26 AM UTC
Please somebody… anybody… help!
Oct 2, 2024 6:34 AM UTC
Hi there,
Thanks for reaching out. I tested this on my end by creating objects with a connector in FigJam and then copying them into Figma. Everything worked as demonstrated in the video, so it appears to be functioning correctly for me.
Could you try the troubleshooting below?
  • Close any Figma tabs you’re not using
  • Browser : Force-quit and open Figma in a new browser window.
  • Desktop App: Force-quit the Figma Desktop app and restart it. If the issue persists, try clearing the cache.
If the issue persists, could you share a bit more detail? Is this problem occurring only in the desktop app? What is your operating system? After quitting the app, can you use the connector properly?
Hope it helps but please let me know how it goes!
Toku
waqarnaik
waqarnaikAuthor
Oct 3, 2024 3:33 AM UTC
Hi there @y_toku ,
I’m using Figma Desktop App. Thanks for the solution, after clearing the caches and restarting Figma solved the issue.
Big thanks again 🙂
waqarnaik
waqarnaikAuthor
Oct 3, 2024 3:37 AM UTC
@y_toku is there a way to make this connector line to component in Figma? I have tried wrapping it in frame and then applying autolayout on it but after using its instance its not working, Any solution!
Oct 3, 2024 5:55 AM UTC
Glad to hear it’s working now!
Regarding the connector line, unfortunately, I don’t think it’s possible at the moment, and I can’t think of a workaround. You’ll need to copy and paste for now. Sorry I can’t be of more help.
Thanks for your understanding.
Toku
waqarnaik
waqarnaikAuthor
Oct 3, 2024 12:57 PM UTC
Sure, btw thanks for the help have a good day mate!
