Drop Shadow effect does not work properly with the new implementation of Remove Background in Figma.
bernardo
I-ve been using a plugin to remove the background of images directly in Figma. After the last update I found out that an option to Remove Background from the Figma UI was there. Fig 1
But after using the Drop Shadow Effect on an image with the background removed using this method, I found out that it is not correctly reading the transparent pixels. Fig 2
I tested the previous plugin I was using to remove the backgrounds and had no issues applying the Drop Shadow Effect. Fig 3
Fig 1
Fig2
Fig 3
Nellya
  • 610 replies
  • April 1, 2025
I have the same problem
PDM ENZ
  • April 4, 2025
i have the same problem! but i’m not using this plugin. i’m having “drop shadow” problem on all png’s…
Pavi
  • April 7, 2025
I have the same problem it’s so annoying
FIGMA YOU GUYS NEED TO FIX THIS!
it only started recently because when the feature first came out it was fine
PDM ENZ
  • April 7, 2025
@Celine_D , ​@Gayani_S
 Can you please check the problem? We haven't been able to work properly for a week, but we have a lot of projects to finish....
P85
  • April 23, 2025
Is there any indication of when this problem is going to get solved?
Nellya
  • 610 replies
  • April 23, 2025
