"Copy link" Doesn't Teleport to Frame/Component Unless in Dev mode
  • October 6, 2023
  • 450 views
Zach_Thomson
I use links to share designs quite often, however recently it has stopped working like it used to.
Figma_pFgA5dMOpD
When opening a link in mode=design it only selects the frame/component. It does NOT teleport you to it. However, if you change the links mode to mode=dev, it selects AND teleports you to it.
I assume this is a bug because it used to have the same behavior for both modes.
I also have open-in desktop app enabled and I haven’t tested it to see if it does the same thing opening in the browser.
  • 3529 replies
  • October 9, 2023
Hi Zach,
Thanks for flagging this!
I can’t reproduce it, it works on my end 🤔. Would you mind sharing a copy of your file and a quick screen recording to our support team here? https://help.figma.com/hc/en-us/requests/new So they can investigate it further. Thank you!
