Changing variable mode in Playground doesn't changes fonts
Bruno31
Hey there,
I’m looking into a component in DevMode and I noticed that when opening the playground, if I change the variable mode, the fonts aren’t changing, like the colors for example.
In design mode, by changing the variable it all works just fine.
Is this a known issue, are there any solutions…?
Thank you!
  • 2545 replies
  • March 13, 2025
Hi ​@Bruno31,
Thanks for reaching out. I tested it on my end, and it appears to be working as expected (see below).
If I'm misunderstanding the issue, could you please share a screen recording of what you're experiencing or provide a little bit more details so we can investigate further?
Thanks!
Toku
Bruno31
  • 5 replies
  • March 13, 2025
This is strange,
Is exactly that what I want to do, and I made a sample like you have and it works, however in my main file (sorry can’t share a video) doesn’t work and is set up the exact same way… Otherwise the variable mode wouldn’t work in Design mode, but only in Dev Mode it has issues
Bruno31
  • 5 replies
  • March 13, 2025
Is it required for the variables to be defined in the same file where the component is? Or is it fine if I have the variables in the “Style Guide” file and the components in the “Component Library”? That’s really the only difference that I see that could prevent dev mode from changing the fonts. But again, the colors are also separated and they work just fine
  • 2545 replies
  • March 14, 2025
Hi ​@Bruno31
Thanks for providing the details! I followed your steps and tested using a variable from the library file, and everything worked fine on my end. Could you please reach out to our support team by submitting a case? You can do so by following the instructions here: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
I hope our support team finds the solution for you.
Thanks for your patience!
Toku
Bruno31
  • 5 replies
  • March 14, 2025
Will submit it, thank you!
