Martin_Marinov
Mar 12, 2025 11:32 AM UTC
Changing component's size inside a other component varaint applies everywhere
I am building a tag component and for now it has 2 sizes. I am using an avatar component inside. For the S size tag I need avatr with size 16 (set as a variant property) and for the tag size M I need to set size 20 avatar. Previously I have done the exact same thing but for some reason when changing the size of the avatar inside the size M tag it gets changed inside the size S as well.
Because I’m rebuilding the components (avatar and tag) I have the absolutely the same setup with the old components and there is no such behaviour. The avatar is the same just split in different variants and the tag has color and other variant adjustments.
In the same tag I’m using an icon component with simillar size setup (with variants) and changing the size in one of the tags does not translate into other variants. It only happenes with the avatar.
I tought it might be because of the aspect ratio since it’s new and I added it to the new avatar but turning it off doesn not change the behaviour.
Mar 13, 2025 5:22 AM UTC
Hi ​@Martin_Marinov,
 Thanks for reaching out. It’s a bit odd that one instance would be affected by another’s properties. Could you try using “Repair component connections” from the Actions menu to see if that resolves the issue?
If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Please make sure you use the email associated with your Figma account, include links to the file in question, and share access with support-share@figma.com. Don't worry, inviting us to view your file won't impact your billing.
Thanks for your patience!
Toku
Martin_Marinov
Mar 13, 2025 7:33 AM UTC
It says “Nothing to repair”. However I think I found the cause of it. I have instance swap property of the avatar (it changes between my avatar and flag components) and for some reason when there is a swap instance property to the avatar any change I make to one of the avatars gets translated to all of them. This again sounds strange as a behaviour
Martin_Marinov
Mar 14, 2025 9:49 AM UTC
​@y_toku any other suggestions?
Mar 18, 2025 5:55 AM UTC
Hi ​@Martin_Marinov
Thanks for adding the extra information! It sounds still weird for me to, so as I mentioned again, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Appreciate your patience!
Toku
Jeremy_Knudsen
Jul 11, 2025 8:50 AM UTC
I’m having the SAME. EXACT ISSUE as Martin and I’m trying to do exactly the same thing. I am seeing this behavior as well.
Jeremy_Knudsen
Jul 11, 2025 8:51 AM UTC
​@Martin_Marinov did you find any solution to this problem?
Martin_Marinov
Jul 11, 2025 9:36 AM UTC
​@Jeremy_Knudsen Yes, this is what I received from Support team. Apparently it’s expected behaviour.
I have checked with our engineering team who has confirmed that this is expected behavior. When layers are bound to the same instance swap property today, swapping out one of them will swap the other layers out as well.
Since these are top-level instances within the variants, then it's expected that the sizes should change when swapping out the instances.
