Can not get color of gradient linear by plugin api
shun1
The gradientStops is empty array
  • April 26, 2024
Having the same issue,
based on your latest release note:
" Paint.ColorStop now has a new field boundVariables that contains a color field and denotes whether a variable is bound to a gradient color stop."
as I understand, the new field should be a new property in ColorStop.
but it’s just returning an empty array.
piusyikyu
  • April 26, 2024
Same issue here, I think it is their data model not being correctly migrated for already existing gradient objects.
If you edit the colour stops, the plugin api will send the data through again.
same problem
shun1
  • April 29, 2024
Is there no official response to this bug?
shun1
  • April 30, 2024
This bug was fixed!
James_Yang
That’s correct. Thank you all for your patience. We rolled out a bug fix for this yesterday.
