Save custom colour in the colour bar
  • April 22, 2025
  • 31 views
Daniela Vitale
How can you save a custom colour into the colour wheel so that you can reuse it without having to type it in over and over again each time you want to use it?
Celine_
  • 3627 replies
  • April 22, 2025
Hey Daniela,
In order to save and reuse custom color in Figma without needing to retype them each time, I’d recommend you to use Color Styles. (It is also the best option to reuse your custom color across your designs):
  1. Select the object or frame you’d like to create a style
  2. In the right sidebar, open the fill color panel and select your custom color. Then, click the four-dot icon next to the ‘Fill’ section corresponding to the style you want to create (the color input)
  1. Click + in the style picker. Select the ‘Style’ tab , then in the modal,  give your color style a name and description and click Create style.
For further details, you can learn in our guide on how to create color styles.
Hope his helps!
