Figma Slides - removed background, bg still shows up in presentation
Tammy_Hu1
I used the ‘remove background’ feature on an image, but in presentation mode, the background still shows up
in the slides:
in presentation, the white background still shows up:
  • Figmate
  • 2034 replies
  • March 18, 2025
Hi ​@Tammy_Hu1, Thanks for reaching out about this!
I noticed the white square section outside the phone frame is visible in the second image.
Looking at the first picture, it seems you're using a GIF in your slide. I was able to reproduce the same behavior using a GIF, which suggests this may be a limitation of the feature.
Could you try using a static image instead and see if that fixes it?
I'll check with the team and let you know if we find anything out.
Thanks again for contacting us!
Tammy_Hu1
  • March 18, 2025
That’s correct it’s a GIF, static images are fine but I need a GIF for the purposes of this deck. I don’t have access to putting in a video because it’s paywalled, and for the sake of presentation would prefer not to embed a prototype.
